India (English)
April 15, 2025
Aranet4 HOME vs Aranet4 PRO: Which One is Right for You?
If you're considering an Aranet4 sensor to monitor indoor air quality, you might be wondering about the differences between Aranet4 HOME and Aranet4 PRO. Some people assume that the PRO version is simply a "better" or upgraded version of the HOME model. However, the reality is that the two devices are designed for different users.
Let’s clear up the confusion and help you choose the right device for your needs.
What Do Aranet4 Sensors Do?
Both Aranet4 HOME and Aranet4 PRO measure CO2 levels, temperature, relative humidity, and atmospheric pressure, providing real-time insights into indoor air quality. These devices are wireless, battery-powered, and portable, making them perfect for monitoring air quality in various indoor spaces.
So, what sets them apart?
Aranet4 HOME vs. Aranet4 PRO: Which One is Right for You?
Aranet4 HOME: The Perfect Choice for Everyday Users
Best for: Homeowners, renters, office workers, and personal use.
The Aranet4 HOME is designed for individuals and families who want to track their indoor air quality easily. Here’s why it’s a great fit for retail customers:
- Standalone operation – Works independently without needing additional equipment.
- Simple and intuitive – View air quality levels directly on the device’s screen.
- Mobile app connectivity – Connect via Bluetooth to the Aranet Home app to track trends and get insights.
- CO2 alerts – A color-coded indicator (green, yellow, red) helps you know when to ventilate your space.
Who Should Get Aranet4 HOME?
If you want a straightforward, user-friendly solution to ensure better air quality at home, in your office, or while traveling, the Aranet4 HOME is the perfect fit.
Aranet4 PRO: Designed for Business & Professional Use
Best for: Schools, offices, industrial facilities, and large-scale monitoring.
The Aranet4 PRO is built for businesses and institutions that need centralized monitoring of multiple sensors. It includes everything in the HOME version but with added features for professional use:
- Connects to Aranet PRO Base Station – Enables large-scale air quality monitoring for multiple sensors.
- Longer wireless range – Can transmit data up to 3 km (1.9 miles) when connected to the Aranet PRO Base Station.
- More data access – Allows integration with third-party systems via an API when used with the base station.
- Supports multiple users – Ideal for teams that need shared access to air quality data.
Who Should Get Aranet4 PRO?
If you need to monitor air quality across multiple locations (such as classrooms, workplaces, or commercial buildings), or if you want centralized data collection, the Aranet4 PRO is the better option.
Which One Should You Choose?
For everyday users, Aranet4 HOME is the best choice. It’s simple, effective, and gives you control over your indoor air quality without needing extra equipment.
For businesses and institutions, Aranet4 PRO is the better fit, especially if you need centralized monitoring and large-scale data collection.
If you're looking for an easy-to-use air quality monitor for personal use, Aranet4 HOME is the right choice for you!
